Go Back  Offshoreonly.com > Owners Forum > Eliminator
33 Daytona Standard Deck? >
Old 05-25-2021 | 08:31 AM
Default 33 Daytona Standard Deck?
Are there any 33 Daytona Standard Decks around with 525's? I have only really seen/heard of one, a 2005 that was at performance boat center years ago.
Probably would have better luck finding a ICC - but I've always been really partial to the appearance of the standard deck.
Needle in a hay stack I am sure...but figured I would ask the experts.
pr1orities is offline
Old 06-15-2021 | 09:25 AM
OkieTunnel's Avatar
I have a 33 standard with 610hp at the Cranks and love it. 525's would run similar. Make sure you get the later bottom design which appeared around 2000 and later. The earlier bottom hopped horribly(search on here for many threads). I don't even have a tab and I plane out quickly at about 1/4-1/3 throttle. Mine takes a nice set and runs real flat. I have had 3 boats with canopies and just didn't like them. I was specifically looking for a standard deck when i bought this one.
OkieTunnel is offline
Old 07-05-2021 | 08:28 AM
OkieTunnel's Avatar
Performance Boat Center just listed a 33 flat deck in the classifieds with the later bottom.
Old 07-28-2021 | 12:20 PM
I have a SD 2000 model with 500's.
give me a call or text 913-940-3010
cagedlx is offline
Old 09-13-2023 | 08:42 AM
okietunnel, what year is your 33? Do you have a side picture of the hull?
rob vanharten is offline
Old 09-13-2023 | 10:57 AM
His is a later 2000 with the small steps, not the sawtooth looking ones that hopped. He isn't on here much but I will text him and let him know you want a pic. I have been on that boat many times and it never hops.
shark42 is offline
Old 09-13-2023 | 11:30 AM
Thank you! Meaning his is a late build 2000 model year or built after 2000 (could be a 2002-2003). My cell is 616-293-5999 if that is easier.
Old 09-13-2023 | 08:56 PM
OkieTunnel's Avatar
Rob, I just posted pictures on the other thread after Shark 42 called me. Check them out. Let me know if you need any other info.
Old 12-05-2023 | 08:54 PM
OkieTunnel, what speed do you get from your 33?
air trap is offline
Old 12-06-2023 | 01:26 PM
OkieTunnel's Avatar
I’m underpropped. I have 625hp per side. I’m on the limiters at 98 but really don’t plan on re-propping because I accelerate like a rocket and mostly cruise below 65 with the Bimini up. Even when I pull the top down I usually don’t cruise much faster than 80–85.
