School me on 1/2 Closed Cooling Systems Please
Hey Gang,
I'm putting together a 26' LS Scarab with a very clean stock 502 EFI with 200 hours (harvested from a Cobalt that lived it's life on Lake Tahoe and has never seen salt) I am moving to Florida and will be running it mainly on the inner coastal waterways - I'd like to protect the motor as much as possible from internal 'rot' and would like input on a 1/2 or full closed cooling system. The motor will have CMI e-tops through hull exhaust.
Thanks in advance!!
Thanks in advance!!
Half , or 'partial' FWC is probably the most common because in a 'full FWC' system the heat exchanger is larger and the plumbing is a bit more complex as they cover the exhaust manifold (but not the riser) as well .
IMO it's worth every penny . Bear in mind that the 502 comes with dissimilar materials like an alloy intake manifold and stainless recirc pump so once you put that fresh water anti freeze mix in you're good to go for a long time.
On a side note, one of the worst things about salt water is the trailer. My twenty year old trailer looked and worked like new until just a couple dunks into salt water. Just one of those considerations for #saltlife.
