Greased bearings??
I'm curious who greases the chit out of their bearings or does the minimal. Meaning, do you fill the whole hub up with grease or just grease bearings.
I have my hubs off servicing the brakes and when I put everything back together am I good with just packing the bearings and placing some grease on the spindle, or should I pack the bearings then fill the whole hub up with grease with the grease fitting on the end of the spindle?
Thoughts?
Thoughts?
Many years ago, I was overkill on maintenance items like that. I would repack every season, new seals, and silicone the cap. No matter how careful I was, I could still tell some water got in.
Now i am at every 2-3 years. Still see some water getting in but no issues. Pack the bearings, Stuff some grease in the hub, few pumps in the grease fittings every now and then, you will be fine. Same results, less work.
Ive learned not to overthink things. Just be prepared. I carry a drum with packed bearings, ready to throw on. Also have additional bearings and seals.
IMHO, the hub should be completely full of grease. The theory being that if there's air in hub heated from the drive, when it gets submerged in relatively cold water, the air will shrink dropping pressure and encouraging water to enter hub.
The prev owner said he would buy a different color grease each season and pump it in till the grease coming out changed color. This means roughly a whole tube for each wheel. I use the same color grease and pump until the grease coming out looks new, still takes abt 1 tube per wheel.
A few seasons back, I got a pneumatic grease gun to speed up this process. It's definitely a lot easier but you can't just lay down on the trigger, it will push out the inner grease seal. I'll hit it for a couple of seconds, then let it rest a couple of seconds, then repeat. So far, so good.
As far as it leaking out, one of the 4 wheels does spit up some grease (on outboard side) and does make a mess. Suspect there's still some air trapped in the hub that expands and pushes some grease out while towing. As I write this, I wonder if maybe jacking up the axle and slowly rotating the wheel while pumping grease might help purge out any trapped air??
I live less than 5 miles from the water, so I only replace bearings/seals every 5 years or so. I'll do the above mentioned grease purge once a season and give them a quick shot of grease every other outing just to make me feel better.
I've always had some sort of 'Bearing Buddies'; so my trailer bearing maintenance was about every two years I'd take the hubs off, inspect the bearings and races, replace as needed (rarely), then I'd hand-pack the bearings good, reinstall everything, then grease up per the instructions on the Buddies.
Baja 252 Islander
Baja 252 Islander
You never said if you have EZlube spindles with the grease fittings and rubber plug on the dust cap. Pretty much what Z28 was alluding to.
My point is, if so they pretty much do just that as in fill the whole hub cavity.
On farm implements you’ll blow the seal if you go crazy with the grease.
I’ve done 3 boat pulls from Fl to Idaho in the last 5 years on the same bearings.
5 shots every morning before leaving the hotel. Never had an issue.
