Bravo to bellhousing install kit oring question >
Old 08-04-2021 | 06:47 AM
Default Bravo to bellhousing install kit oring question
Question pertains to pn 16755Q-1.
The oring that goes around the oil passage, what part number is that? I have a new water passage and shift oring, but not the oil passage. Is it #4 in the parts fiche? If not I’ll buy the whole kit and go from there.
cloudmaster_321 is offline
Old 08-04-2021 | 07:18 AM
The oil passage O ring is the one you have in pic. It should come in the 16775Q1 kit
AllDodge is offline
Old 08-04-2021 | 07:53 AM
SB
Edited
SB is offline
Old 08-04-2021 | 08:50 AM
i didn’t buy the kit. The other two orings came with the drive after rebuild, and I noticed the oil passage oring was missing on the bell housing. I pulled the drive last fall, so probably fell off and I didn’t notice. So just need the oil passage o ring, which, if #4 is it, I happen to have 2 of in my stash of parts.
Old 08-04-2021 | 09:14 AM
#4 is correct
AllDodge is offline
Old 08-04-2021 | 09:59 AM
#4 is correct
ok, thanks for the help
