454 mag backfiring won’t rev up.
I rebuilt a 454 mag mark IV engine and it’s not revving past 2300 and popping out the intake. I’ve been changing things for the past month just wasting money with no results. It’s bored .030 over, 10.29:1, 185 on each cylinder, comp camshaft broken in properly and verified after no lobes were destroyed, thunderbolt ignition. I’ve changed cap, rotor, coil, plugs, thunderbolt ignition module, reset valve lash, swapped carb with one from a running 454 engine, drained all 75 gallons of gas and put fresh 93 in, new fuel pump. Vacuum gauge reads 13 inches at idle, sprayed starter fluid all around intake with no change in rpm. Timing is 8° at idle and advances smoothly while revving up. I think I’ve checked everything but I’m lost. Any help would be appreciated.
I would be checking fuel pressure while eng is under load. We had a member recently suffering very similar issues and it turned out to be a collapsed inner lining of fuel supply hose severely restricting fuel flow.
Ethanol laced fuel and old school hoses don't play well together.
Another possibility is excessive spark plug gap. 0.035" is the almost universally accepted gap for any configuration. This is especially important for forced induction or high compression engs.
It is I believe second gen thunderbolt IV on the triangular plate. V8-24. How can I check pressure under load? I have the rubber fuel line from tank to filter than it’s all metal lines from there to mechanical pump on the block to carb. Cut the metal line and put some kind of T between pump and carb?
Plugs were gapped correctly, have tried different manufacturers plugs as well.
-Compression - 185 on all cylinders (~3or4)
-carburated so no connector to test fuel pressure
-carb I swapped with was from another 454 mag I built for a friend a few years back. Both motors are 454 mag
-don’t have a distributor to swap with, don’t know what tb module is but cleaned the ignition module in distributor
-I will change 3’ rubber line to tank. I’ll post results when it stops raining (Thursday)
-checked plug wires 40x, has brand new marine wires. Under load timing light didn’t pick up any cross firing.
- cam is comp cam, cam is bigger but not anything crazy
