Rooke Question; Hardin Bravo Sea Pump >
Old 08-29-2021 | 01:28 AM
Default Rooke Question; Hardin Bravo Sea Pump
I just dropped my single SBC in the boat, it is normal rotation, the pump rotates the same direction as the motor. Can anyone confirm which nipple is in and which is out please, thanks, I appreciate it.
tbev is offline
Old 08-29-2021 | 06:55 AM
Motor is LH rotatio. The top port list LH OUT, that one goes to thermostat housing
AllDodge is offline
Old 08-29-2021 | 07:01 AM
Is that motor raw water cooled? Your thermostat housing is going to cause some issues if so.
Unlimited jd is offline
Old 08-29-2021 | 08:29 AM
SB
In addition: Fuel pump not marine. By chance is anything else ? Distributor ? Alternator ? Starter ? Carburetor ?
SB is offline
Old 08-29-2021 | 04:54 PM
Quick question. Did the Harden Pump come with the impeller installed
thanks
3pointstar
3pointstar is offline
Old 08-30-2021 | 03:12 PM
Just to confirm, if you look at this motor from the front, like most other similar motors, the crank is rotating clockwise, that makes it LH Rotation as far as the water pump is concerned.
Thanks AllDodge I appreciate it.
It's a closed cooling system, this is in my old fishing boat, it's a Skipjack 24 Flybridge, getting ready to go kill some big tuna.
3pointstar Impeller was installed by Hardin.
tbev is offline
Old 08-30-2021 | 05:21 PM
Correct, RH facing front and LH facing the flywheel.
AllDodge is offline
Old 08-30-2021 | 06:21 PM
Thanks bud!
tbev is offline
