Go Back  Offshoreonly.com > Technical > Electronics
94020 Adapter Wiring Schematic >
Old 09-10-2021 | 04:37 PM
Default 94020 Adapter Wiring Schematic
Hello everyone,
I, like many, have had a hard time locating a 94020 adapter to scan for hours on my TB-V. I saw someone on here mention they were able to get the wiring schematic from Rinda but they never shared it with group (or maybe I didn't look hard enough) and I HATE when someone solves something without SHARING. So I created an account just to share what I found because I know it will help someone somewhere.
I attached the schematic to my profile album since I can't post here.
I know for sure that the wiring will work for a Gen 2 and 3 ICM with a MerCruiser / TechMate Scan Tool, I'm not sure about Diacom (someone chime in).
Gen 2 will require only the Yellow and Violet Leads (no need for the 4 pin connector).
Gen 3 does not need the Yellow and Violet Leads as its being used in the 4 pin connector.
minteeeze is offline
Old 09-12-2021 | 09:15 AM
no link in your post
sutphen 30 is offline
Old 09-13-2021 | 08:47 AM
It's on my profile album. I can't attach until I get to 10 posts
Old 09-13-2021 | 10:24 AM
Old 03-06-2023 | 08:40 PM
Can you send me the schematic
Jcleary93 is offline
Old 03-06-2023 | 08:59 PM
Here are the pics from his profile album
Griff is offline
Old 03-06-2023 | 09:01 PM
Just post numbers 1-6 in 6 more posts in this thread.
Griff is offline
Old 03-07-2023 | 02:41 PM
Thanks Griff..
Also, if I remember correctly, you need to attach the black aligator (negative) clip to your block and the red aligator (positive) clip to your battery. It won't work if you attach both to battery.
Another thing, the 4 pin connector is off a suzuki gsxr hayabusa starter relay.. Just google "hayabusa starter connector" and you'll see it on amazon and ebay for about $9. You'll only use 3 of the 4 pins
The 6pin din was the hard part to find. Search the numbers below on amazon and it should pull up what you need.
B00K855H1E
B0978QX3Q8
Old 03-07-2023 | 02:43 PM
I got banned doing that before
Old 03-08-2023 | 12:42 AM
I'm one of the moderators, so you can post away.
Griff is offline
