Transom Replacement Coosa or Wood >
Old 11-04-2021 | 11:20 PM
Default Transom Replacement Coosa or Wood
Having my transom replaced in my Baja 36 Outlaw. Coosa was suggested by my builder but I cannot find much on using it in a heavy performance boat. I'm concerned with strength vs plywood. Treated plywood is pretty much rot proof as well. What's everyone doing with the bigger boats?
SnoNinja is offline
Old 11-05-2021 | 12:33 AM
Veteran: Navy
This about says it all about Coosa. Also, who ever told you that, "Treated plywood is pretty much rot proof", is just wrong. Listen to your builder.......
https://coosacomposites.com/the-coosa-advantage/
AmiableDave is offline
Old 11-05-2021 | 07:25 AM
I would not use Coosa in the transom. I used it everywhere else. I don't think it will handle the compressive loads near as good as wood.
Glassdave is probably the guy to ask, he has way more experience with the stuff.
kvogt is offline
Old 11-05-2021 | 06:35 PM
Outerlimits has been using it for close to 20 years now. Worlds fastest vee bottom has a composite transom
Unlimited jd is offline
Old 11-05-2021 | 06:47 PM
Curious about what thats costing you if your willing to share
Big_Baller is offline
Old 11-06-2021 | 07:21 AM
bencini231's Avatar
A PVC foam core, such as Divinycell is another option and has been proven in boat building. Pat @ Active Thunder uses this in his boats and the test boats that he builds for Mercury to use at their testing grounds.
bencini231 is offline
Old 11-06-2021 | 08:45 AM
How long did the wood transom last the first time?
phragle is offline
Old 11-06-2021 | 01:26 PM
So, it's like a lighter weight StarBoard? HDPE?
SabrToothSqrl is offline
Old 11-06-2021 | 02:11 PM
Veteran: Navy
Starboard is nothing like Coosa.
Old 11-08-2021 | 11:06 PM
Not long enough!
cheech is offline
