Marinediesel/BUKH VGT450 with MSA 300sxr drive >
Old 11-11-2021 | 01:32 AM
Default Marinediesel/BUKH VGT450 with MSA 300sxr drive
Hello,
I recently bought a boat with this engine and drive. I want to ask maybe who has set like this? Need information where the problems are. Because after removing the engine I found the R&D damper destroyed. is it a weak spot?
Engine: Marinediesel/bukh VGT450
Gearbox: zf63a
Drive: msa 300sxr
Tadas is offline
Old 11-12-2021 | 09:52 AM
mcollinstn's Avatar
Damper/coupler is always a potential weak spot, especially if alignment is not perfect.
I would send photos and info to R and D Drivetrain Products and get their input.
I've done driveline repairs/upgrades for construction equipment, and the only ones that are truly bulletproof are the Cat type with the center core supported on roller bearings with the viscoelastomers solely used to absorb torsional pulses. Couplers that rely on the damping material to maintain concentricity are prone to failure if there is any misalignment..
mcollinstn is offline
