Blower Shop 250 Supercharger on a 454 EFI Magnum >
Old 12-07-2021 | 07:25 PM
Default Blower Shop 250 Supercharger on a 454 EFI Magnum
Looking for recommendations and advise on what upgrades to make on a 454 Mag EFI (385 HP) for reliability. Goal to obtain a nice flat torque curve and around 550 to 600 HP. (Is this reasonable with the 454 and the smaller blower without creating issues?)
Engine has zero hours, but understand I’ll need to tear it down as it’s been sitting since new. Would like to stay with original crank and rods and heads, but open to all recommendations from top to bottom including getting it blueprinted, internally balanced, improved oil cooling system, hydraulic roller setup, head work, valve upgrade, different headers, etc.. I want to do it the right with quality parts.
Chappy1967 is offline
Old 12-07-2021 | 08:52 PM
454 mag.. I ran 8.5:1 with akracing alum heads 731 cam and a 177 blower and was over 650 so your goal is easy. I did go with a big pan, hv pump and larger lines along with the big wix filter.
phragle is offline
Old 01-02-2022 | 03:40 PM
phragle, how much boost we’re you pushing and info on your carb(s) setup?
Old 01-02-2022 | 04:38 PM
CArb is single Bill Mitchell worked dominator, and I have 2 pully sets, one makes 4psi the other makes 6
phragle is offline
