Baja 342 weight
Old 12-07-2021 | 09:04 PM
Default Baja 342 weight
Everything is saying 8200lbs dry, My question is how is that 8200lb boat equipped? A/C, generator? Anyone out there have a real answer on the weight of a 342 w/twin 500efi's(headers) no genny, no A/C? Also any idea of what the trailer/tow weight is ? Thanks for any help.
Shotgunn is offline
Old 12-07-2021 | 09:52 PM
I have a 342 with 500EFI’s, no gen, no AC on an aluminum trailer. My understanding is that the 8,200lb weight in the manual and brochure is dry weight without the gen and AC. While I have yet to actually put it on a scale, I estimate that it’s about 10,500 on the trailer. I keep minimal equipment onboard and the water/holding tanks are always empty. The fuel tank, when built without a gen, is 185 gallons so factor that in to your total weight too. With the 500EFI’s, it’s a great running and very comfortable boat. I may be able to arrange for it to be weighed if you need an absolute answer.
Baja_260 is offline
Old 12-08-2021 | 05:51 AM
Thank you ! I am in the process of getting one. I have an F350srw, I think it will be up to the task, but was wondering about the hitch, any special stabilizer bars needed? Do the gen equipped models have a larger fuel tank? What is your top speed with those engines?
Shotgunn is offline
Old 12-08-2021 | 07:43 AM
You’ll love it. Your F350 will have no problem. Most recent Ford factory receivers indicate that a weight distributing hitch is required to achieve the max towing capacity. I only use mine when I’m on highway runs though, not to my local ramp. I also have EOH disc brakes and it tows very nicely. Gen equipped models have a smaller 145 gallon fuel tank. I run stock 30 pitch Bravo 1’s and get about 80 MPH at WOT. Cruise speed is 50 MPH at 3,000 RPM burning approx 23 GPH.
Baja_260 is offline
Old 12-08-2021 | 08:16 AM
I have a 2004, about 8 years ago when repowered I was trying to move the CG back and lighten the boat for speed and ride. I took the generator out, removed all old wires, removed shore power wiring and stripped the cabin of seats, under the bed I used a 4inch and 6 inch hole saw to remove excess brace supports like a race car) and took the plywood out of the bed and replaced with composite panels. Replaced a lot of the kitchen panels with 1/8 and 1/4 carbon fiber panels. I have 2 batteries that I moved to the back at the transom. With no fuel I still weighed in at 8200, I would suggest a boat with accessories, stuff in the cabin and fuel would weigh 9200 minimum -10,000 depending on if you have a genset, and a bunch of tools, toys and bullchit. That is actually kind of conservative....
I can tell you from experience, its hard to remove weight, and the stuff you have under the front 2 cuddy seats, under the bed and under the sink probably weighs 200lbs+. I bought a scale and weighed all my stuff. Literally just putting your tools under the back seat and anything other than a float noodle in the cabin is good for faster planing, higher speed and better ride.
Keith Atlanta is offline
Old 12-08-2021 | 05:39 PM
Excellent! This one has factory extension boxes, and previous owner claimed" 80 on a good day", so that sounds like he wasnt embellishing. Trailer is EOH discs, but not aluminum. I will have to pick up some bars for the hitch, so if I do go to another lake I will have them. Due to our hobby gaining in popularity, my lake was PACKED every weekend last year with lots of big boats and a few mini yachts lol. It was really choppy, I am looking forward to the upgraded ride.
Shotgunn is offline
Old 12-08-2021 | 05:45 PM
F-2 Speedy's Avatar
dont know what year your truck is, mine had a class 3 hitch from the factory and I put a class 5 on
F-2 Speedy is offline
Old 12-08-2021 | 05:51 PM
I have always been a minimalist when it comes to gear. I doubt I will even use the water stuff much, and was gonna delete the microwave. The engines have hours on them, so next winter they may get stroked with aluminum heads.
I wanted a 302, but just could not find one. 10000lbs is a bit porky, but it should be pretty comfy.
Shotgunn is offline
Old 12-08-2021 | 05:54 PM
Good call, mine is a class3.
Shotgunn is offline
Old 12-08-2021 | 08:06 PM
Yes, depending on ext box height, 80 should be doable pretty easily with lite load, lite fuel and labbed props. With boxes it changed mine dramatically in ride and speed it probably picked up 2-3 over no boxes (ride is really really nice with boxes!) . With Raylar 600's I am upper 88ish MPH in perfect conditions lite chop. Tried like hell to break 90 but never could. If you have boxes, get your props labbed by BBlades, made a huge difference for me.
