Engine silent option
Old 03-28-2022 | 07:41 AM
Default Engine silent option
Recently picked up a 1999 29 Scarab. I was told it has engine silencers on it. Can anyone tell me how I turn that on and off?
Thanks!
Jimmyplante is offline
Old 03-28-2022 | 07:56 AM
resurrected's Avatar
Welcome to OSO, you will need 9 more posts for permission to post pictures. They don't need to be meaningful.
Then post pictures of your setup (engine compartment, transom and dash) and someone will be able to help
resurrected is offline
Old 03-28-2022 | 08:06 AM
ok. I will post some pics.
Old 03-28-2022 | 06:08 PM
It may just have mufflers or it may have Silent Choice exhaust. Silent Choice would have switch on the dash.
Griff is offline
Old 03-28-2022 | 06:41 PM
rak rua's Avatar
If you have Silent Choice, Captain’s Call or similar, it will have a toggle switch on the dash. Last one I had read “open” or “closed”. Lift your engine hatch and look at your exhausts, they have the manifold with pipes going straight out the back through the hull and also pipes diverting downwards to to the bottom of tne sterndrive. That is silent choice/captains call etc…….
If the pipes just go straight out through the transom only, you may still have mufflers fitted which are not switchable. Have a look at the outlets from behind the boat. Are they empty pipes or do they have a larger pipe fitted around them? They may have baffles inside the pipes?
Not sure if Scarab ever used the big mufflers like some Sea Rays had, exhaust came from the manifold and down towards the sides of the boat and into a large round sealed muffler (Looks like a big bucket) then out through the sides of the hull.
Good luck. 🙂
RR
rak rua is offline
Old 03-30-2022 | 09:22 AM
I am going through this right now its such a pain
Patrick Irish is offline
Old 03-31-2022 | 02:03 PM
scarabman's Avatar
Originally Posted by rak rua
Not sure if Scarab ever used the big mufflers like some Sea Rays had, exhaust came from the manifold and down towards the sides of the boat and into a large round sealed muffler (Looks like a big bucket) then out through the sides of the hull.RR
They did on singles, of which his 29 could be. He doesnt say.
scarabman is offline
