water Pressure >
water Pressure
water Pressure
Old 04-04-2022 | 03:21 PM
Default water Pressure
How much water pressure is to much? at 90 mph i have 35 PSI that's about where it maxes out at . Motors did not have thermostats and water pressure was around 10 PSI . I added stats and now its 35-38 psi .
2015Duramax is offline
Old 04-04-2022 | 04:52 PM
TomZ's Avatar
What engines?
My 502s seeped water out the sides… I was seeing 30 lbs at cruise speed/laying the needle on the stop all out (above 35 lbs).
You might want to bleed some pressure off. 20 lbs is more than enough.
TomZ is offline
Old 04-06-2022 | 01:01 PM
Curious as to why you went back to stats?
Tractionless is offline
Old 04-06-2022 | 01:17 PM
SB
Under 30psi, if you are in there controlling things shoot for no more than 25psi ???
SB is online now
Old 04-06-2022 | 02:01 PM
Originally Posted by TomZ
What engines?
I’d venture to say NA 580’s. There’s a few good threads on cooling and dumping water etc. In fact I even started one a couple years ago + - Some good info that I grabbed and went with.
getrdunn is offline
Old 04-06-2022 | 02:32 PM
TomZ's Avatar
I might have been on that thread. I had a thread showing the damage done to my blocks from the overpressure. I never got a chance to plumb my pressure regulators to see what the benefits may have been (and with closed cooling I won't need them now) but I do know they were a mess to clean up when I was prepping the blocks for the machine shop trip.
TomZ is offline
Old 04-06-2022 | 03:51 PM
order some 15 lb water dumps from Teague, you'll be glad you did
PROP STAR is offline
