Plugging flush mount cleat drain hole
Any reason I can’t just plug this drain hole up? I have two small cleats that I’d prefer to just plug. I assume the water would just puddle and then evaporate? If so anyone know what fitting it is? Doesn’t appear to be 1/8 NPT it’s very coarse thread…..
https://www.boatoutfitters.com/flush...16=772&215=866
Come to find out they have been draining directly on the foam behind my upholstery. there is a wood/fiberglass mount directly under it so running a drain tube would be hard - probably not enough clearance.
I’ll just plug
I’ll just plug
