Offset lifter bores in roller blocks? >
Old 04-07-2022 | 04:12 PM
Default Offset lifter bores in roller blocks?
Are the lifter bores in a Gen 6 block offset like flat tappet blocks? Yes I'm wanting to put a flat tappet cam in there.
stinkbomb is offline
Old 04-07-2022 | 04:20 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
My Gen 6.
the deep is offline
Old 04-07-2022 | 04:30 PM
Originally Posted by the deep
My Gen 6.
Looks offset to me but is it?
Old 04-07-2022 | 05:23 PM
Lifter bores are in the same place. I have a gen 6 block here someone put a flat tappet in.
Unlimited jd is offline
Old 04-07-2022 | 08:34 PM
SB
X 100.
No such thing as offset bores. You can put flat tappet cam and lifters in there if you want. But do you really want, really really want ?
SB is offline
Old 04-08-2022 | 05:30 AM
Interesting, so a roller cam has the lobes moved on center of the lifter bores? I'll have to measure that if I get my hands on a flat tappet cam one day.
Old 04-08-2022 | 06:46 AM
Originally Posted by SB
X 100.
technically the flat tappet cam lobes aren’t centered in the lifter bore so the lifters rotate.
The roller cam lifters aren’t centered over the lobe either.
And why would you want to use a flat tappet?
Old 04-08-2022 | 07:27 AM
can only get a 3/4 race cam in flat tappet.
sutphen 30 is offline
Old 04-08-2022 | 07:46 AM
SB
SB is offline
Old 04-08-2022 | 07:48 AM
A good flat tappet in my application will have more longevity. Guys think 200 or even 500 hour top-end rebuilds are acceptable but I don't, not for what I'm doing.
