BB valve covers, MSD and thunderbolt 4  distributors >
Old 04-11-2022 | 06:36 PM
Default BB valve covers, MSD and thunderbolt 4 distributors
Finned valve covers $50 Angled valve covers paint peeling, easily removed $100 Thunderbolt 4 dist w/new style pickup, slight play in lower bushing $25 MSD distributor $75 pay pal, shipping avail. Text 914-262-1898
Btrhd is offline
Old 05-09-2023 | 04:03 PM
Hi Guys.. first post.
I realize this is an older thread, but I have a question about these type aluminum Mercruiser high performance covers. I've build a decent 454 (400ish hp) for my 25 Bertram. It has some roller tip rockers that fit under the low stock valve covers, but only with stock valve stud nuts. The set came with the allen wrench, extended stud locks that I would prefer to use.
So the question is: Will this type cover clear the extended stud locks (like are used on roller rockers)?.... AND will they work with the STD Mercruiser cast iron center riser manifolds. Its not a hot rod, but the hot rod in me needed to play just a bit.
I looked at the Eddie Marine angled valve covers made just for this type thing, but just can't justify $400 valve covers on this project. BTW the painted set in this post looks like the Eddie Marine covers.
Thanks in advance,
Scot
Scot is offline
Old 05-09-2023 | 04:21 PM
F-2 Speedy's Avatar
They made a couple different length polly locks and Id think both would fit under these covers kinda hard to tell from the pics.......... if the flamer ones are not angled on the exhaust side not sure if they'd clear your riser..jmo
F-2 Speedy is online now
Old 05-09-2023 | 04:41 PM
Thanks.. do you think the black cast aluminum pieces would fit with the cast center risers?
Scot is offline
Old 05-09-2023 | 04:55 PM
F-2 Speedy's Avatar
if they are Mercury Id say yes but if the are an automotive tall then Id say no........how tall are both ? maybe some others will chime in
Old 05-10-2023 | 04:57 AM
I’ve got a set of merc finned finned covers in great shape if interested. Painted yellow and never used.
getrdunn is offline
