CMI split tube clamps. >
Old 04-11-2022 | 07:36 PM
tfarmer's Avatar
Default CMI split tube clamps.
Hello all, I have a question on my CMI Split Tube headers. I bought these used and needing to know what clamps I need when connecting the tails? I think someone one said they had a second design for them. They are 4.5 tails. Also where is the best place to order them. Thanks, Timmy
tfarmer is offline
Old 04-11-2022 | 07:52 PM
F-2 Speedy's Avatar
Looks like a rope seal ? need a close up pic of the flange, could be v-band
F-2 Speedy is online now
Old 04-11-2022 | 09:20 PM
Those are slip fit, no clamp. You put a bead of silicone around the header, then slide the tail over it. A bolt through the 2 brackets holds them together.
Unlimited jd is offline
Old 04-12-2022 | 07:41 PM
tfarmer's Avatar
I'll get close up pics tomorrow. Just to make sure.
tfarmer is offline
Old 04-13-2022 | 12:26 AM
This may just be what your in need of, for the split-tubes
Big Tube Rope Seal Clamp Assembly Kit - CP Performance
I'CE is offline
Old 04-13-2022 | 06:21 PM
tfarmer's Avatar
Yes that's the one's I'm thinking too. It looks like the tails could go together just a little more but that's as best I can get them.
tfarmer is offline
Old 04-13-2022 | 07:32 PM
yep ice is correct. The first pics looked like they were similar to the stellings slip fit.
