Newer Full hydraulic steering upgrade >
Old 05-03-2022 | 11:17 AM
Default Newer Full hydraulic steering upgrade
I'm working on 28' single engine V-bottom with a older version of hydraulic steering Hynautic is the name of it.
I have removed the entire system and replaced it with Latham Marine rams 2" bore 8" stroke and all new HP lines. I'm running a remote reservoir GM power steering pump and I'm looking for the information on how to select the right steering motor for 4 turns lock to lock. I believe the GM power steering pump is a 6.5 GPM speck and the lines are rated to 6000 PSI.
I just need to know a part number or how to get the right specs on what to look for.
Any information would be greatly appreciated thanks
PS Nobody at Latham is any help
FORMULAfast is offline
Old 05-03-2022 | 12:07 PM
Imco's chart on page 70 will get you close https://imcosteering.com/imco-catalog-2022-v5.pdf
Griff is offline
Old 05-03-2022 | 05:39 PM
You can go several ways with this. I found a local shop and had custom made lines, stainless hose and ends. They had a crimping machine to put on the ends.
jeffswav is offline
Old 05-04-2022 | 09:44 AM
I have already had the lines made I have the 2" bore 8" stroke rams all I need is a steering motor thats 4 turns lock to lock
Old 05-04-2022 | 01:20 PM
Rookie's Avatar
You have 25.13 in³ of fluid per cylinder. (π•r²•H) So, 50.26/4=12.565 you need a helm that is ~12.5 in³ per revolution. That is if your cylinders bottom out not you transom assemblies.
Rookie is offline
Old 05-06-2022 | 12:27 AM
I assume you mean hydraulic helm when you say steering motor?? The chart I posted a link to gives enough info to get real close. Looks like you need either a 100cc or 125cc helm.
Griff is offline
Old 05-09-2022 | 10:43 AM
Yes I mean steering helm
Ok thank you for the information
