Alternatives to running or flushing 496 on hose "ear muff"? >
Old 05-07-2022 | 08:16 PM
Default Alternatives to running or flushing 496 on hose "ear muff"?
What setup do you use to running 496 on the hose? I sometimes see folks running the hose into the engine compartment. I imagine you can install a hose attachment before the engine mounted water pump. Does anyone have a picture of this type of setup?
Mariah212Z is offline
Old 05-08-2022 | 04:40 AM
Veteran: Army
You can install a flush kit that which will Tee into the hose that supplies the raw water pump. Eddie Marine sells a few kits that include everything you need, including the garden hose hookups.
DrFeelgood is offline
Old 05-08-2022 | 07:13 PM
bencini231's Avatar
I use a connection on my sea strainers. One of the best things installed on mine, since it catches stuff before it gets to the sea pump and I can use it to run the motors on the hose.
bencini231 is offline
Old 05-09-2022 | 10:11 AM
jadento's Avatar
Perko Flush system Perko Flush system
You will get mixed reviews on here. But I have never had a problem with them.
John
jadento is offline
Old 05-09-2022 | 11:20 AM
I made my own flushing set-up. I bought a pc. of the red hose and the plastic quick connectors on ebay. I added a tee with a garden hose fitting. I simply disconnect the red hose in front of the water pump and I stick my other pc. in to the plastic quick connect. Works like a charm. I had tried the Perko plastic flush kit I bought but the orange anti-freeze made it brittle and it broke.
MonkeySea2 is offline
Old 05-09-2022 | 06:12 PM
2nd the perko one.
I've considered installing a second one with a valve so I can flush without running the engines.
SabrToothSqrl is offline
