Steering pump failure >
Old 05-07-2022 | 08:20 PM
Default Steering pump failure
Merc 496 with Latham steering. Blew seal on pump, lost almost all the oil. Anything can cause seal to give out all at once? Never saw any leakage before. Is pump rebuildable or buy new pump. Got really hot!
2john is offline
Old 05-07-2022 | 10:45 PM
TomZ's Avatar
It’s probably done. I’d replace. This thread may be helpful:
496 power steering pump
TomZ is offline
Old 05-08-2022 | 11:38 AM
Shaft broke. What would put it in such a bind to twist off.
2john is offline
Old 05-08-2022 | 12:48 PM
Veteran: Army
Odd. does the remaining part of the shaft still turn? Or is it locked up? Would have to guess a bearing fell apart and jammed things up.
DrFeelgood is offline
Old 05-08-2022 | 02:55 PM
Haven’t pulled pulley off yet. Pulley with part shaft turns easy.
2john is offline
Old 05-08-2022 | 06:52 PM
Rookie's Avatar
Steering cylinder bottomed out or lock up during a tight turn. I had the same thing happen to me on my 496 truck. Backing the boat in my my pole barn turning the steering wheel hard. Snapped the power steering shaft. I lost breaks from the hydro-boost and steering. Fun ride back home...
Rookie is offline
Old 05-09-2022 | 06:39 AM
articfriends's Avatar
Thats crazy, my buddy jeff builds/blueprints power steering pumps for 75% of the nascar cup teams and a bunch of other stuff, Im going to ask him how common that is and if he makes a upgrade shaft!
articfriends is offline
Old 05-09-2022 | 07:20 AM
SB
Interesting.
I haven’t seen it in the car/truck world, but seems some have like Rookie:
https://www.google.com/search?q=brok...-wiz-serp#ip=1
SB is online now
Old 05-09-2022 | 06:39 PM
Looked closer at mine today with auto mechanic friend. Pump has bushing and no bearing. Bushing seized to shaft and spun in housing. Probably why it got so hot. So don’t know what happen first, seal blew first maybe causing lack of oil. Looking at Hardin marine pumps because I believe they’re available. Have their water pumps and have been good.
2john is offline
Old 05-15-2022 | 07:43 PM
Pump no longer available. Anyone have part number replacement. Got a 8m0110722. Doesn’t fit bracket. Is a recall replacement for 8.2, got it from merc.
2john is offline
