Battery switch problem
I have two batteries and a Blue Seas manual switch. When the starboard side is on I get good voltage to the dash and engine. When the port side is on I get almost nothing at the dash and will not turn over the engine. A vom at the battery reads 12.4 volts. All connections at the switch are tight and corrosion free. Where do I go from here, please?
Padraig
Padraig
Padraig
Padraig
SB I get good voltage at both inputs...when switched on nothing at output terminal. Therefore bad switch??? I assume better to replace them disamble and try to fix? Any thoughts on better switch?
F-2 Speedy Not your fault...I should have described boat. Thanks!
snapmorgan Does notcrank...Thanks
Padraig
Padraig
Padraig
Padraig
I use Amazon for reviews. Lots of good info buried in there. The Blue Seas switches have fallen apart internally on several peeps. None that i can find find with the perko’s.
Blue Seas:
perko:
Blue Seas:
perko:
