Correct Quadrajet for 365 magnum 454 >
Old 05-23-2022 | 01:45 PM
Default Correct Quadrajet for 365 magnum 454
I have a 454 mag mpi long block I'm going to put an intake and carb on . I already have the 454 mag carb intake with the bronze water passages . I'm looking for a Quadrajet that came off a 365 mag. From my research it looks like it should be carb # 17059280. That confuses me a little because when I Google that number listings come up for a 5.7. Anyway , maybe somebody has a Q-jet they know came from a 365 mag . Thanks
tooslow is offline
Old 05-24-2022 | 06:07 PM
maybe its the same part number but with different jets...
j272 is offline
Old 05-25-2022 | 06:45 AM
I was trying to find a chart that showed what Jets, metering rods , hangers etc each carb had but I can't find one . Maybe I could modify my 330 454 carb to work . I do have a Holley as well , I could do plug readings and jet it accordingly. I figured the 365 mag and 7.4 mag mpi had similar compression , similar heads and similar cam I could just slap a 365 mag carb on there . But I'm open to advice .
tooslow is offline
Old 05-25-2022 | 07:06 AM
Active Streak: 30 Days
What year motor are you trying to duplicate? That carb part number in the Mercruiser manual for a 454 Mag MCM370 shows Primary jet size .069 in, .041 (marked DA) secondary metering rod and hanger "F". There also a note that the hanger listed may not be correct, to install the same hanger as what was removed. Contact Mikes Carbs, they are located in WA, they have everything you need. Good luck.
www.carburetor-parts.com
Helmwurst is offline
Old 05-25-2022 | 07:59 AM
Thank you for the info . I don't know if this is even a good plan , but the engine im trying to " duplicate " is a 1988-1992 454 MAG Bravo . Looks like the serial numbers of engine would be 0B721206-0D805068. I'll call Mikes Carbs.
tooslow is offline
Old 05-25-2022 | 08:46 AM
I have a pair of carbs from 1988 365 horse 454 Mags. They were both on the original motors and running last season.
Steve888 is offline
Old 05-25-2022 | 09:06 AM
Hi Steve , I sent you a PM
tooslow is offline
Old 05-25-2022 | 02:19 PM
Steve I tried to return your PM , it says your mailbox is full . Can you call or text me ? Six one 7 eight 93 0502 . Thanks
tooslow is offline
