Gen VI 454 oil lines , filter adapter >
Old 05-27-2022 | 07:41 PM
Default Gen VI 454 oil lines , filter adapter
I am putting together a Gen Vi 454 . I have an extra set of mark iv accessories to use . I also have the seawater pump/ fuel pump . From my reading I think I need the piece that mounts to the filter pad on the block and some hoses ? I would also need a cooler. Im learning as I go , im not 100% sure what I even need . Thanks in advance
tooslow is offline
Old 05-29-2022 | 08:54 PM
I would source aftermarket.. the lines and fittings on stock are barely adequate.. depending on your horsepower you can size your cooler accordingly
smokediver is offline
Old 05-30-2022 | 12:46 PM
Yes , the more I read about it I agree with what you are saying .
tooslow is offline
Old 05-30-2022 | 01:40 PM
Hardin Marine is your friend. Use Summitt Racing for the lines and fittings.
GLENAMY 242SS is offline
Old 06-01-2022 | 12:42 AM
Default Oil lines
I have everything you asked for from a gen 6 454 mpl I can send you pics if you still need
Stephen Ramage is offline
Old 06-01-2022 | 06:44 PM
PM sent
tooslow is offline
