Whats going on with these Gil Exhaust Manifolds? >
Old 06-05-2022 | 03:04 PM
gripit's Avatar
Default Whats going on with these Gil Exhaust Manifolds?
Whats going on with these Gil Exhaust Manifolds? They all seem to be having some sort of corrosion under the powder coating in the same area. They are pressure tested good but can't figure out whats going on. Running in Bracish water and flush on a regular basis. Thanks
gripit is offline
Old 06-05-2022 | 06:15 PM
That is where the casting holes are. In your first pic, you can see the faint circle. After years and years of heat cycles, they prob got microscopic cracks in the powdercoat. Tiny amounts of moisture and air get in and the corrosion just builds over time.
Griff is offline
Old 06-05-2022 | 06:28 PM
gripit's Avatar
What do you mean by casting holes? Please explain.
gripit is offline
Old 06-05-2022 | 09:33 PM
Thee are made similarly to an engine block to create the hollow water jacket. The holes are plugged and then they get powdercoated
Freeze plugs on gil manifolds
Griff is offline
