Another bravo failure >
Old 07-14-2022 | 01:48 PM
Default Another bravo failure
Anyone ever seen this before? These were purchased brand new last June, gear oil changed 3 times in 20 hours, all clean and good, this year put on about 10 hours, then out of no where it was hanging up getting out of reverse. Drive shifted in/out forward perfect, into reverse perfect but got tight pulling it to neutral. Upon arriving to the dock to load up, approx 10 min ride, the final time it was put in reverse it stalled the port motor. I'm thinking part failure??? Just looking for some input on what you guys think.
Drive was assembled last year using all mercury specialty tools, all tolerances within mercury shop manual specs, only used mercury high performance 90wt gear oil
blownhammer2000 is offline
Old 07-14-2022 | 07:21 PM
my first question would be what motor is in front of this and what is the idle speed?
compedgemarine is offline
Old 07-14-2022 | 09:42 PM
496HO, idle speed 650, never shifted above idle speed
Old 07-14-2022 | 11:05 PM
I had the clutch cup shear off of the gear with maybe 10 hours on it but
that was due to a crack in the gear between a tooth.
if the gear is still ok, I know the bravo shop sold the bump rings
( which merc doesn’t)
JaayTeee is offline
Old 07-15-2022 | 06:23 PM
I am guessing no one used Green Locktite when they installed the Brass ring at the factory, so it came loose and jammed up till it broke the ring,,I have seen several of these where the ring came off,,improperly installed at factory.
253 is offline
Old 07-15-2022 | 07:59 PM
I was thinking it was a factory defect myself, so I'm glad to hear that, I'm submitted a warranty claim with mercury soi guess we will see, of course it happened 2 weeks outside the 1 year warranty on parts
Old 07-16-2022 | 08:20 AM
good luck with Mercruiser warranty,, do they warranty anything
253 is offline
