Suddenly lost water pressure and got overheat alarm...
...on my 525 EFI which resulted in a tow. I carry towing insurance through BoatU.S. so the tow cost nothing. I first checked the intake hose which is clear and has no leaks between the drive and the sea strainer. I took the pump apart which is a Hardin marine SS pump, second generation and 2 years old. The impeller looks fine. I suppose that next I'll start looking for an obstruction and backflush the various coolers but I am running a sea strainer. Any other ideas where to look? After letting the engine cool, on startup it would pump 5 psi momentarily and then back to zero with very little water visibly flowing through the sea strainer. Thanks.
Large O-ring and the wing nuts were tight. I will look further into any possible air leaks on the intake side though. Also it will be getting a new impeller while it is apart. (that pressure relief valve and hardware are gone now)
No blockage. I stuck a hose tight into the inlet in the strainer and could freely blow through it. I then had a friend block the intake on the drive with his palm and I could not blow through it. I plan to back flush water through it and look for any water leaks in the hose but this doesn't appear to be the problem. I also blew compressed air through the hose. I also suspected an intake side problem but haven't found one.
make sure you buy Merc or Q silver impellers not the knockoffs
https://www.ebay.com/itm/33271501529...cAAOSwCR9cnVV6
If I'm following the progression of events correctly, you were on plane when you lost water press. Shutdown and got towed in. After it cooled, you restarted and got 5 psi at idle for a little bit then lost water press again. If that is correct, then maybe you ran over a plastic bag and it wrapped itself around the drive shutting off the water. Bag falls off while being towed in. When bag blocked water flow, it created a very high vacuum within the pump inlet hoses and caused the inner and outer plys to separate from each other within a short section of hose. Now when you restart at idle. The normal vacuum inside the hoses causes the delaminated inner hose ply to collapse and shut off water flow. Outside of hose looks fine. Just a WAG.. Not even sure if the hoses are 2 ply.
I've seen this happen with a vacuum hose once. Drove me nuts for hours.
