Prop pitch vs rpm 24p t0 23p
thanks
If the slip remains constant, then I would say 24 / 23 x 4700 = 4904 rpm. If you turned the 4700 rpm in the summer, then the 4904 rpm with the 23P could become 5000 - 5100 rpm in cool fall or spring weather.
I called Hydromotive, first new props are way behind getting made. Stated props are sourced by foundry. He stated best to do is have prop tuned/lab which should get the 100-150rpm without increase slip numbers because doesn't change cup. Currently have 12% and if I would go to 23p would be losing about 2mph mid range which I guess would increase GPH since would need to increase RPM to maintain MPH. So I'll wait to winter.
