Target afr numbers >
Target afr numbers
Target afr numbers
Old 07-24-2022 | 03:48 PM
Default Target afr numbers
Good afternoon,
working on a blown 555 with Holley terminator efi and I need suggestions on target afr numbers
idle seems to like 13.7 at 850rpm
whats a good number for 3500 -2 psi vacuum
and up?
can you read a new plug at partial throttle?
coltonkloack@gmail.com is offline
Old 07-24-2022 | 05:59 PM
GPM
What size is the boat, I'm guessing 12.0 to 12.3 under low boost, 11.9 at higher boost. Rich is safer than lean.
GPM is offline
