Fountain: 89 Executioner or 97 27 Fever? >
Old 08-01-2022 | 11:05 PM
Default Fountain: 89 Executioner or 97 27 Fever?
Still shopping....
97 27 Fountain Fever w/500 Blue Block
OR
89 Fountain 10 meter Executioner w/fresh 500s
I'm guessing both are mid to upper 70mph boats.
Strong opinion on one vs the other? Upper Chesapeake Bay cruising, no offshore runs, not trying to get to 100mph but rather a fun reliable boat to cruise around in on occasion,
Both are asking 35-40k with trailer for both.
SeaNile31 is offline
Old 08-01-2022 | 11:59 PM
rak rua's Avatar
Check them both very carefully for moisture in transom and stringers, if only one has moisture, buy the other one!
If both are wet, be prepared for lots of work. If both are dry, and engine maintenance doesn’t bother you, I’d go with the bigger boat. Size matters!
RR
rak rua is offline
Old 08-02-2022 | 12:09 AM
In those water's I would get the 10 meter hands down. You can do a lot with that boat around there and will use the bigger cabin.
TexomaPowerboater is offline
Old 08-02-2022 | 12:37 AM
That is an apples to oranges comparison. Totally different boats other than both are Fountains.
Griff is offline
Old 08-02-2022 | 05:20 AM
OFFSHOREJOJO's Avatar
Is TRS on 10 meter? Do research on both go with bigger hull my 02 good luck!
OFFSHOREJOJO is offline
Old 08-02-2022 | 08:48 AM
TeamSaris's Avatar
Driver-441
Racer
If the exhaust tips come through the transom with a plastic beauty ring- the transom is toast. This is true for all used fountains.
TeamSaris is offline
Old 08-02-2022 | 09:23 AM
I'll post a pic of the transom. Thanks fo the help along the way.
Old 08-02-2022 | 09:24 AM
Old 08-02-2022 | 10:02 AM
I agree..apples to oranges. Put condition aside for a moment:
Do you want a single or twins? The 27 is a lake boat with a tiny gas tank. The 10 meter is a classic for sure but old hardware.
Other than price I don't see cross shopping these two. But all things considered if the 10 meter presents as good as the much newer 27....go bigger.
techman is offline
Old 08-02-2022 | 10:21 AM
The 10 meter will let you go out on the boat most days. With the 27 you'll be concerned about winds and waves.
Interceptor is offline
