Vapor lock 525 EFI fix? >
Old 08-03-2022 | 06:52 AM
Default Vapor lock 525 EFI fix?
Would replacing original fuel cooler unit on 2005 525 EFI's eliminate vapor lock? Annoying issue. OEM replacement part;8M0125854 - COOLER KIT-FUEL
Markd15668 is offline
Old 08-03-2022 | 06:21 PM
Make sure you've got good fuel pressure. AND that it doesn't bleed off when you shut the engine off. Then make sure there's no obstruction in the cooler.
Smitty275 is offline
Old 08-03-2022 | 08:33 PM
thirdchildhood is offline
