Busted axle覧vin decoder for the trailer >
Busted axle??vin decoder for the trailer
Old 08-15-2022 | 04:34 PM
Default Busted axle覧vin decoder for the trailer
I have a double axle trailer. The bearing buddy Somehow came off and I smoked all the bearings inside. It ruined the spindle. I need a new axle. I have the Vin for the trailer so I can figure out if it takes 3500 or 4500 pound axles. I can稚 seem to find a good Vin decoder online. It is from 1992. The axles are not stamped in any way that I can see to figure out what the axle actually is. anyone know a way to decode the vin?
Batmeat is offline
Old 08-15-2022 | 04:42 PM
Sydwayz's Avatar
Forum Regulator
Your best bet is probably just ordering two new axles. They are not terribly expensive. It is 5 lug hub? Chances are it's a 3500 lbs. axle if so.
Sydwayz is offline
Old 08-15-2022 | 04:46 PM
yep 5 lug. Did find max trailer weight is 6k lbs. Gota be 3500lb axles. They池e a drop axle though. Gota figure out how to measure the drop height.
Batmeat is offline
Old 08-15-2022 | 04:54 PM
Sydwayz's Avatar
Forum Regulator
https://mechanicalelements.com/trailer-axles-101/
Sydwayz is offline
Old 08-15-2022 | 05:45 PM
that is a fabulous read. Thank you!
Batmeat is offline
Old 08-15-2022 | 07:50 PM
i would look up etrailer you can buy everything you need
flat rate is offline
Old 08-17-2022 | 07:55 PM
SABER28's Avatar
bought mine from boattrailerparts.com . they sell tie down engineering axles . mine was galvanized torsion drop center with removable spindles. nice guys , they went out back and got me the measurements that were not listed in the web page.
in stock and shipped to me in four days.
now the jokers at manning trailer , thats a 1 1/2 year long story
SABER28 is offline
Old 08-22-2022 | 10:32 AM
Fountain38's Avatar
look up southwestwheel.com they will have everything you need
Fountain38 is offline
Old 08-23-2022 | 08:40 PM
Try Decodethis.com, free vin decode for vehicles and should include trailers if Mfr is registered with NHSTI..
Powerquest230 is offline
