prop rake measurement
You are on a different level than me here so keep that in mind while reading my questions.
Are these new or have you run them already?
If you ran them was there a difference in rpm?
Did all of the blades of each prop match each other?
This may have been answered by the results of a previous question but what made you check in the first place.
I don't think you are measuring correctly. Look at your hub reference point in the first picture. It is elevated above / past the trailing edge of the blade altering your measurement as compared to the lower picture. Imagine the hub shaft extended out another three inches. Your rake measurement would be negative based on your measuring method. This obviously would not be correct as hub length has no bearing on prop rake.
I believe prop rake is measured from mid-chord at the root (hub) extending to the tip and measured from the prop rotational axis. This gets difficult to measure with multiple compound curves associated with many props.
I also think these angles should be measured from the C/L of the shaft bore, not the rear face of the hub. We would all hope that face would be square to the bore, but there's no guarantee it will be.
Thanks. Brad.
(937)545-8991
Keep in mind that, when they say, "differs from perpendicular", they are referring to a line perpendicular to the prop SHAFT. The problem you have is that you are trying to measure the angle of a line from a relatively short reference area (the hub). On a prop with an even number of blades, this will be particularly difficult, as the blade opposite will interfere with the resting of any gage longer than the diameter of the rear hub face. You obviously have 5-blade props, so that's not an issue, but you still have a fairly short reference plane to measure from, assuming that surface is perpendicular to the shaft. It would serve you well to find or have made a dummy shaft that fits the bore in your props that you can measure your rake angles from. Remember, the prop is rotating around the shaft, not the rear face of the hub.
In my world of precision machining, I have to eliminate as many sources of error as possible. These habits are hard to shake for me.
Thanks. Brad.
(937)545-8991
