Transverse muffler solution
In the 80s, my Dad built a set of stainless exhaust manifolds for a 350 powering a Volvo 280 drive.
It was/is in an 18ft K&C boat. Just a regular runabout made in Vancouver BC.
What they did was also fabricate a transverse muffler system, that mounted up close to the transom. All wet flow, that exits to thru-hull with flappers. The intent was to maximize flow, while eliminating a lot of the bark from thru hull exhaust.
It seems this would a good solution to a lot of the bark issues from thru-hull and maintain high flow.
I like a good V8 bark as much as the next guy, but muzzling it to an acceptable level without being abnoxious, would be great.
On my Glen-L Thunderbolt, with Nixon ex manifolds...no risers...I can look into the hull port and see the ports to the head.
I'm looking at making up a transverse muffler system for my Formula 233. With TRS, it has even more room to have a tuned exhaust system.
Likely go with EMI manifolds, and fabricate risers to drop and feed the muffler, to thru-hull.
Was thinking injectjng the raw water in the muffler vs risers...to prevent reversion, and get better cam timing.
Mastercraft boats do something kind of similar. Not a muffler per say but puts it under water to make it quiet. Lol. It’s called ‘Fresh Air Exhaust’ just because puts exhaust inwater vs in air bothering skiers/boarders.
Anyway - i like your thinking. Keep us up to date on your progress.
Nice looking setup.
My Thuderbolt exhaust isn't too bad in the boat...but wherever the back end is pointed...is rugged.
A proper manufacturer ski boat would have to have a quiet exhaust to keep the girlfriends and wives happy... !!
One of the factors I have to contend with, is what height to make the thru-hull on the Formula 233. It has the factory swim grid, but I'm not against moving it up a touch.
I wanted to beef up the swim grid slightly to mount a 2-Stroke kicker. Something easily mounted in some water...and not obtrusive. But I hate the idea of a single.
Here is the 350 Volvo 280.
Drive has about 20k hours on it. Mostly all original. Well maintained.
