Let the restoration begin...
I have started to disassemble my 22 Velocity. The first thing to go was the swim platform. It's a very nice platform, but just too large for the size of my boat. The old Alpha will come off along with that transom assembly and then the holes from all of the prior swim platforms and Pitots will be filled and the transom can be buffed back up. Soon the engine will be pulled and taken over to BES Racing engines. I went ahead and pulled the trigger on a set of AFR 185 CNC heads over the World Products Sportsman 2 heads which are currently on the engine. We are expecting somewhere between 476-500 HP out of the 383 Stroker once Tony works his magic on the little Small Block. The interior will come out and be taken to a local shop that I have worked with before and does very nice work. I've decided to go ahead and paint the white gel coat on the deck and touch up the imron and then cl;ear the whole deck. Everything else buffed up very nice. Rob Jones will be building a Carbon Fiber insert for the dash and then all new Livorsi gauges will be put in place. While everything is out of the boat. We plan on flipping it over and cleaning up the hull which shouldn't take more than a few small patches in the gel coat and then a good buffing. The old Alpha set up will be replaced with a Bravo one set up including a -2 shorty lower. The boat should be very nice once this project is completed, because it's not that bad now.
finish off.
finish off.
The cam going in the engine specs are as follows with a 1.6 rocker arm. 576/555 I/E, 271/297 adv dur. and 216/223 @.050. 106/118 centers and a 112 LSA
I'm guessing you're a mind reader as well as a master engine builder. From Tony's mouth to my ears. Quote "We should be able to make 475-500 HP out of this little engine" One would think that being that master engiine guru you believe yourself to be. You would know that the same cam used on a set of 200CC as cast intake runner Sportsman 2s Wouldn't be the same as the cam used on a set of AFR 185 CNC heads. Don't you think? I'll make sure to post the Dyno numbers once I have them. Now please add me to your ignore list. I'd certainly appreciate it.
I quoted the EXACT cam that you stated you were going to use. Now you are going to use a different one? Isn't it funny that when I call you out on a piss poor cam choice that it all of a sudden is not the one you are going to use. What, is everything going to change when people who actually know how to build engines tell you how many wrong parts your parts picker got wrong?
LOL...You're a riot. The sad part is that you probably believe the crap you spew. Hey Einstein... I'm also using a different set of heads which dictated the different cam. You're a legend in your own mind. Now please take a hike. Life is full of enough imbeciles without you adding to it.
Just because you changed heads doesn't mean you changed the cam.
Your lack of knowledge is what happens when you let a parts salesman tell you how to build something.
