Alpha SS fitment question
Hi All,
I recently acquired and Alpha Ss and noticed that the diameter of the portion of the upper housing that inserts into the transom assembly is smaller. This results in the large o ring being pretty loose that forms the seal in the bellows area.
has anyone else run into this? Am I supposed to be using a different installation kit? I don’t this it’s a major problem as I don’t have exhaust running through the drive but thought it was I’d that the non ss and ss had different diameters.
thanks,
Jason
thanks,
Jason
I have one and not noticed it that way.Mines on a gen I and actually squeezes that oring s bunch. It leaves marks/indentions on it ftom that big spanner nut ir whatever it’s called. Your’s 1 or II ? Can they even be mounted on a II ? I don’t remember. Prob not.
