Winch stand bow stop.
Guys, I have this contraption for the bow stop on my trailer. It is a total ***** to get the boat on the trailer in low water and has led to scratches on the hull and drivability issues (bouncing, etc). The black rubber stops don’t even last all that long.
Can I just get rid of the tilting stop and replace it with a bow roller or is the tilting stop needed for some reason? I don’t see a lot of trailers made with this anymore.
Thanks,
Thanks,
A V-stop is the way to go. Something like this.
https://venturetrailers.com/product/...mbly-carpeted/
I had that setup on one of my boats and modified it soon after I used it a few times. Depending on how the boat hits it, you might be able to take the whole pivot setup off and replace it with one round bow stop. If not, some slight modifications will work. Old, bad quality pictures but it will give you an idea.
Picking up a roller is cheap. I may try that first.
I had to dip the boat four times to get it close enough to leave the ramp. It still wasn’t on as solid as I’d want it but I’m only a couple miles from the ramp.
I find that with the length of these Formula 311s, the angle of the ramp has a lot of influence and I have to focus on getting my bow snug against my stop. My Venture aluminum trailer came with this:
https://venturetrailers.com/product/...ller-assembly/
It was low tide and my buddy was the one that attempted to get it winched up while I was driving it up. I thought it was good to go until I got down from the boat and we ready to leave. There was a good two inches of distance too and bottom… back in she went… four times to get it close enough. Even then it wasn’t perfect.
It seems from searching that many have issues with the type of stop I have on this trailer. I’m going to run out to the trailer shop (Portsmouth Trailer) this week to see what they might have on hand that I can use.
