700sci keeps loosing exhaust flapper on port side >
Old 09-19-2022 | 07:34 PM
Default 700sci keeps loosing exhaust flapper on port side
Alright, so the title basically says it all, my port side exhaust keeps loosing the external flapper..noticed it was missing about a month ago and at that point it was less then a year old. No big deal, replaced it and first day out with the new flapper and same deal, flap gone..torn from the top. Any ideas??
formulavt is offline
Old 09-19-2022 | 07:55 PM
How’s your water pressure at idle? How is the temperature of that header vs the other?
Unlimited jd is offline
Old 09-19-2022 | 07:59 PM
May be getting too hot.
Is it getting same water flow as right side?
zz28zz is offline
Old 09-20-2022 | 08:27 AM
Its rained every day since Saturday up here, next decent day I will hook it up to water and see if I can find something. I didn't not notice any water pressure issues or temp issues on Saturday when I was running the boat..I would really like to figure this out before I have to winterize!
Old 09-20-2022 | 08:51 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Definitely check out the water pressure. You may not find much out running it on the hose either. You may have to back it in the water and rev it up a bit to get an accurate picture.
You could also upgrade to these:
https://www.hardin-marine.com/p-1257...-flappers.aspx
Sydwayz is offline
Old 09-20-2022 | 09:08 AM
F-2 Speedy's Avatar
I have 4 on the shelf if ya need some.............
F-2 Speedy is offline
