Anyone convert from carb to FI? >
Old 09-23-2022 | 04:46 PM
Default Anyone convert from carb to FI?
After burning through $400 in fuel the last time I was out, it got me thinking about FI. I'm running a 1050 Dominator now, so about the furthest thing from fuel efficient. I only have a 60'ish gallon tank, so it feels like I'm constantly running low on fuel.
Has anyone made the swap or have a comparison what to be expected from carb to FI? What are people running for aftermarket FI? In the car space a lot of people were running FAST, Holley, etc. If it's significant change in fuel efficiency a FI setup could damn near pay itself off over a few seasons. Not to mention the manners you get with FI.
540Fever is offline
Old 09-23-2022 | 05:05 PM
General rule is EFI is about 5-10% more efficient. It will of course depend on how dialed in the carb was vs the EFI tune.
Griff is offline
Old 09-23-2022 | 05:11 PM
Its HP to weight ratio = fuel burn
What boat, what motor?
AllDodge is offline
Old 09-23-2022 | 05:52 PM
Significantly noticeable gas savings when I switched to Holley EFI.
ICDEDPPL is offline
Old 09-24-2022 | 12:59 AM
If carb and FI are tuned to same AFR there are zero difference to fuel consumption. You can install AFR gauge in your boat and tune carb perfectly. I had Baja 29 OL with twin 600hp carb motors, holley 950’s. I tuned it 14.5AFR idle, 3000-4000rpm 13.2-12.8AFR, 4000-WOT 12.7-12.0. Four channel EGT gauge help tuning alot. Egt was in all situations below 700Celsius. It tell how rich you must go.
ksalmine is offline
Old 09-24-2022 | 06:59 AM
SB
On average, an in-tune four-stroke gasoline engine will burn about 0.50 pounds of fuel per hour for each unit of horsepower. On a dyno chart theis fuel use would be under the BSFC (brake specific fuel consumption). Typical marine engine around .5 bsfc.
Unleaded gas weighs 6.1lbs per gallon
200hp x .5 bsfc= 100lbs/hr
100lbs/hr / 6.1 lbs/gal = 16.4 gal hr
so 400hp uses 32.8 gal / hr
600 hp = 49.2 gal/hr
SB is offline
Old 09-24-2022 | 07:02 AM
It takes some time to tune the carb precisely, but it is well worth it. Only injection i would use over the carb is sequential 8 point injection. Group member articfriends has good info about the fuel distribution problems of the carb intake manifolds, wich i think could be fixed with 8 point EFI. Anyhow there is many in this site that likes their sniper style tbi, much easier to tune than carb.
JaniH is offline
Old 09-24-2022 | 07:24 AM
Since most carburetors AREN'T "optimized" generally speaking a carbureted engine will be ~10% less fuel efficient overall than a fuel injected one. Of course we've all seen cases where the carb was really out of tune and had excessive fuel consumption, but that's a problem unto itself.
My personal experience comes from comparing my Baja 208 Islander to my 252 Islander; both with 454 engines, the 208 was a Quadrajet engine and the 252 a MPI engine. The 252 is ~1000 pounds heavier than my 208. The 208 had a 42 gallon tank, the 252 a 90 gallon tank. Based on historical fuel consumption-to-destination with both boats, running very similar speeds, the 252 actually gets slightly better "mileage" than the 208 did. It amazed me, frankly, to the point I was questioning the fuel gauge when I first got my 252.
Baja 252 Islander
bajaman is offline
Old 09-24-2022 | 08:17 AM
Has anyone attempted a lean cruise tune?
I’ve also seen some car guys do it. Apparently the exhaust valve gets hot. Also some Aussie cars were tuned like this from the factory.
I think youd find your common cruising RPM and look at the map sensor to dial out like 5% fuel? Not sure how lean you could go. I’m still around 2/3 max fuel rate at my cruise RPMs.
hogie roll is offline
Old 09-24-2022 | 08:50 AM
F-2 Speedy's Avatar
F-2 Speedy is offline
