suck or blow? >
suck or blow?
suck or blow?
Old 10-01-2022 | 05:12 PM
Question suck or blow?
I wanted to run cool fuel thru the pump but now i`m not sure the pumps are that good at sucking .
maybe it should be on the pressure side?
Thoughts ?
ICDEDPPL is offline
Old 10-01-2022 | 06:11 PM
Rookie's Avatar
If the filter head is above the pump I see no issue pulling fuel through the cooler. I assume currently there is not an issue with the pump drawing through the filter.
Rookie is offline
Old 10-01-2022 | 11:48 PM
I`ve looked into this and those Pumps are gravity fed and don`t like to suck.
I`ll be changing that over to cool the return fuel.
ICDEDPPL is offline
Old 10-02-2022 | 07:32 AM
Pumps in general don’t like to suck. Diaphragm style pumps can do it best. Gerotors can do it, but are sensitive to debris and the manufacturing tolerances. Centrifugal pumps can’t do it at all.
I would put anything that’s not a filter downstream.
hogie roll is offline
Old 10-02-2022 | 07:57 AM
SB
Least restriction possible to inlet of electric fuel pumps.
SB is offline
Old 10-02-2022 | 05:20 PM
At this point in life I’d settle for either one! 😂
getrdunn is offline
Old 10-02-2022 | 05:28 PM
suck, Mary Beth, blow means suck. not my joke but still funny.
compedgemarine is offline
