Goosneck
Old 10-19-2022 | 02:58 PM
Question Goosneck
I need to transport some big pieces of rail supports to a job in Chicago for work, the trailer i have isn`t large enough. I can borrow a Goodneck 40' trailer
I ordered my truck without a 5th wheel ... what is involved in getting that installed ..?
ICDEDPPL is offline
Old 10-19-2022 | 03:08 PM
Veteran: Army
It's a doable DIY job, at least it was when I installed a B&W gooseneck hitch in my '02 2500HD. Important distinction too between 5th wheel and gooseneck, they are not interchangeable if you're buying a hitch, though adapters are available.
Hardest part is cutting the hole in the bed in the right spot. Everything else is pretty straightforward if it's a well engineered kit.
DrFeelgood is offline
Old 10-19-2022 | 03:36 PM
BBYSTWY's Avatar
It's easy....drill some holes tighten some bolts...couple hour job at best. Buy a good one however...B&W was mentioned or from the dealer...can't remember if you have a dodge or chevy but all the big 3 offer a hitch kit for their trucks just a matter of if you can get one...
BBYSTWY is offline
Old 10-19-2022 | 03:37 PM
BBYSTWY's Avatar
And in all honesty....pulling the bed makes it soooo much easier and it's only a few bolts and a plug to do so...
BBYSTWY is offline
Old 10-24-2022 | 06:58 AM
The Ram has a cast iron gooseneck plate that sits under the inside one of the frame cross members and is held in with 4 bolts. Probably easiest to remove the bed to instal. Ram and other companies offer a removable ball and safety chain hooks. It's really pretty easy to install with the bed off and the bed comes off easy. 4 -6 guys can lift it.
The 5th wheel drops into the 4 pucks that install into the frame. Again bed needs dry be removed. I think you could have a fifth wheel without the gooseneck but not the gooseneck without the fifth wheel since the safety chains clip into 2 of the fifth wheel pucks. Might as well install all 4 pucks and the center gooseneck plate while the beds off.
I have a new aluminum 40' triple axle deckover tag trailer you can use too bad we are not closer.
offshorexcursion is offline
Old 10-24-2022 | 09:51 AM
Thumbs up
I have an appointment for later in the week to have it installed, B&M gooseneck kit .
ICDEDPPL is offline
