Trailer Level Point
Old 10-20-2022 | 01:29 PM
Default Trailer Level Point
I am setting up my Myco behind my new tow rig and was trying to figure out the best method for making sure the trailer is level behind the tow rig.
If I place a level on the fenders just above the axles is that the optimal spot to do it from? If I place the level on the side rails nearer the coupler I get a slightly different reading. Almost like the rails have a subtle rise before they get to the nose of the boat trailer.
I assume if I get the things level above the tires/axles ( I have two) when hooked up that is optimal? I have an adjustable mount/ball hitch.
techman is online now
Old 10-20-2022 | 01:52 PM
Put a 6 foot straight edge on the frame, I would think the frame is a much better indicator, the fenders are just covers for the tires.
Wildman_grafix is offline
Old 10-20-2022 | 02:15 PM
Good point. I'm sure Myco would say there fenders are spot on!
Old 10-21-2022 | 05:37 AM
Quinlan's Avatar
I usually just measure bottom of frame to ground to see if close.
Quinlan is offline
Old 10-21-2022 | 11:58 AM
SABER28's Avatar
i think you are over thinking it. just stand back and eyeball it. your trucks trailer ball is going to change height depending on the weight in the truck anyways.
SABER28 is offline
Old 10-21-2022 | 01:27 PM
Yeah, being a little too sensitive on the setup. The truck has air suspension so that will help even things out too.
Old 10-29-2022 | 01:43 PM
Just take it down to the ramp and give it the ramp test (5:20 mark and beyond)
Jupiter Sunsation is offline
Old 10-31-2022 | 12:34 PM
Same here. Measure near the front and the rear of the trailer
Griff is offline
