Mercruiser 'blue' block and manifold plugs - what thread? >
Old 10-20-2022 | 12:48 PM
Default Mercruiser 'blue' block and manifold plugs - what thread?
It's definitely NOT 1/4" NPT, it's definitely not 1/2-13...does anyone know the size of the threads in a Mercruiser big block and exhaust manifold? I have one that is kind of buggered and needs chased with a tap as I have new blue plugs to put in, all the others went in fine.
Thanks in advance!
Baja 252 Islander
bajaman is offline
Old 10-20-2022 | 12:53 PM
SB
Be more specific where these plugs are, and if adapter or brass/plastic oringed wing nut or ? thanks .
SB is offline
Old 10-20-2022 | 12:55 PM
F-2 Speedy's Avatar
Survey says groogle
The thread of the blue plug is 1/2-13.
F-2 Speedy is offline
Old 10-20-2022 | 12:58 PM
SB
I didn’t read the title.
yes, merc blue oring plugs are 1/2-13.
So aren’t the ss replacements
https://www.hardin-marine.com/p-8108...74-5-pack.aspx
SB is offline
Old 10-20-2022 | 01:08 PM
Hardin Marine SS ones are exceptional. Use a little anti-seize on them.
The Merc ones lately are so brittle. Maybe get a season out of them.
techman is offline
Old 10-20-2022 | 01:10 PM
SB
If you need either block adapter for blue plug or exh manifold elbow with blue pkug, they aren’t too expensive.
SB is offline
Old 10-20-2022 | 03:00 PM
Interesting. I can't get my plugs to screw into a 1/2-13 nut but they go fine in a metric 14mm - 2.0 nut, like...perfect.
Baja 252 Islander
bajaman is offline
Old 10-20-2022 | 03:22 PM
SB
Sometimes with cheap pos manufacturing nowadays, you just gotta do what you gotta do. Unfortunately. Merc can't make sbc manifolds and risers line up, so I'm sure their blue plugs aren't all that exact.
I replace several a year with the boats I work on. I don't have any real problem with them until they just break while the boats under way. Old and brittle I guess. Whenever I remove them I clean off the thrads and squirt some wd40 or silicone or whatever is in he boat with me, therefore I don't have to tighten them much, which keeps them from snapping off.
SB is offline
Old 10-20-2022 | 03:24 PM
SB
I forgot to mention, last time I got the Hardin Marine SS plugs, I got them from Michigan Motorz because their shipping is fair, Hardin MArine / CP Performance usually not.
Here's the link per piece:
https://www.michiganmotorz.com/stain...ugs-mercruiser
SB is offline
Old 10-20-2022 | 03:41 PM
Wow, thanks...I have tried to get these in the past only to be told they were sold out and on backorder...just ordered (5), so yeah...cool and thanks again.
Baja 252 Islander
bajaman is offline
