Are Merc. #2's drives the same thing as a TRS drives >
Old 11-27-2002 | 05:58 AM
Dean Ferry's Avatar
Veteran: Air Force
Question Are Merc. #2's drives the same thing as a TRS drives
Are they?
Thanks,
MD
Dean Ferry is offline
Old 11-27-2002 | 06:51 AM
Becca's Avatar
They are not exactly the same but are interchangeable, are you taking blown TRSs off of a Cig or something? #2s will bolt right on in place of them but the boat will behave differently
Becca is offline
Old 11-27-2002 | 06:58 AM
Payton's Avatar
Charter Member #927
The #2s are longer, so your prop will run deeper.
Payton is offline
Old 11-27-2002 | 07:39 AM
BODYSHOT1's Avatar
Payton,
the #2's are longer than the TRS??..didn't know that..I assumed they were shorter..
thanks!
BODYSHOT1 is offline
Old 11-27-2002 | 08:09 AM
Doller Offshore
Smile answer from the expert, John Klumpjan
The major difference is the Lower, the lower is a speedmaster, twin shaft. The upper is the same. the length from center line to center line is the same. It will sit just about the same as a TRS, but if you are replacing a TRS, you will slow down. There are no more parts available, so if you are replacing TRS's, you are certainly better off going with Bravo or current drives, instead of trading what is becomming obsolete for what is already obsolete. We would need to know your application, HP, etc to better assist you. If you would like to speak to John directly, please phone him at 800-376-1616, he will be happy to explain it all to you.
Lofty
Swap Shop
1
07-31-2008 10:29 AM
frogger1403
07-19-2006 08:33 AM
muffin
10-16-2005 11:04 AM
Elite Marine
16
03-03-2003 07:46 PM
