Fountain Fever 29 Cabin >
Old 10-28-2022 | 02:58 PM
Default Fountain Fever 29 Cabin
2003 Fountain Fever Cabin continues to stay wet. I am not storing with cover on boat. Hangs on lift in sealed boathouse. Only place I can find that water is Front anchor storage area. Where does this area drain? Is there an area that could hold water from this area? Anyway, need as much help locating the source of this moisture. Carpet stays wet/damp. Moisture is causing headliner to detach from ceiling of cabin. Very little to no water in front bilge area.
jim2826 is offline
Old 10-29-2022 | 11:07 AM
I have a 1998 fever 29 with twins and I have same issue if your talking about the area when you go into cabin and lift up step area , I have a bulge pump in there , have no clue how but it's always has water in but no water in engine bay....... on another note are you able to take a picture from one of the access panels on side to show the nuts on the bolts that hold the interior peices in , I just had my interior redone and the guy lost the hardware and he put some crap nuts on there with 2 small of washers and I need proof That he did it wrong and could really use the pictures I will Zelle you money if you can take those pictures for me for your time , I paid 15k for Interior and very Unhappy with the quality of how he put it back together.. I'll send you 50$ for your time his is SUPER IMPORTANT, to me as he's coming by today to see and collect balance that I'm not giving him , you can also text me 4 eight zero 294 five 7 five 1 , please if you can do this it would be great thanks Robert
Robert Dunsmore is offline
Old 10-30-2022 | 08:20 AM
Just fixed this on my 32. First your anchor locker should have a little drain, take the mirror off in the cabin and look, maybe its clogged.
The other place is the rails, these boats are old and the caulking gets bad, let alone how many times have we all tied lines to the rails? They really are not made to have that force on them.
Either way I loosened mine up and dug all the old out and resealed with 4200. No more water.
its not a hard job but a bit of a PITA, and if you take the bolts all the way out the rails will spring a little. You will need two people then.
Wildman_grafix is offline
Old 10-30-2022 | 08:52 AM
The other place is the rails, these boats are old and the caulking gets bad, let alone how many times have we all tied lines to the rails? They really are not made to have that for e on them.
This is my plans for the off season for my 32. I had in my mind to start at the front behind the mirror.
Never been a huge problem for me because it stays in a garage and trailered to the lake on weekends.
Well this summer my boat was in the parking lot during a heavy rain. Soaked my new cabin carpet. I doubt it would have gotten my carpet wet if it was in the water. Anyways, I hope this fixes the problem so it won’t happen again.
jtbooten is offline
Old 10-31-2022 | 08:01 AM
Boat is at shop getting ready for upholstery. Have not disassembled yet. I can get pictures once taken apart but do not have borescope to send pictures
at this time. Further comments on my request is confirming my issue,but have not resolved as of yet. From what I have learned there is some water that will
always infiltrate the front bilge area due to possible leaks around rub-rail seams or anchor drain. I have borescope pictures sent to me from where I replaced the
gas filler hose and overflow hose if that will be of any use.
jim2826 is offline
