Volvo 8.1GXi and Merc 496HO... Same camshafts ???
Just curious if these use the same cams/cam specs... as the Mag and HO engines are rated at same HP levels as the Gi and GXi VP's...
Both manufacturers took the stock 496 from GM and did their own thing in terms of accessories, but the internals are the same (cams/etc). It was a price point engine so Merc and Volvo didn't do any digging into the internals. The Merc's were actually rated slightly higher on engine output, 5HP for each model. Software and and a slightly less restrictive exhaust on the Merc side.
Looks to me like they are the same camshaft.
I just bought one to see what exactly it is.
Yep, the same core engine.
I had a 8.1 GXi and now have Merc 496 HO's. They couldn't be more different in terms of execution. The Volvo MEFI 4 software was just awful and it just never ran right in the HO model. The Gi was a little more forgiving. The Merc PCM 555 was superior in everyway.
Theres a local guy that swears he can do it... but I cant get him out here until Jan/Feb... so I am in a holding pattern right now.
so you have a 496 HO cam to go off of? Let me know your findings because I would like to know my self in case I need one.
Ill update later when I have solid numbers... but I expect the GXi cam to be same/similar.
Looking for full Specs on stock 425hp 496HO cam
