700sci prelube after engine rebuild >
Old 12-08-2022 | 05:59 AM
Default 700sci prelube after engine rebuild
Hey guys,
would appreciate if anyone could assist me explaining to me the process of prelubing the engine after rebuild
i have built my preluber in house and would like to know where should I connect the hoses on the engine to run the oil through. If anyone has pictures would be of great help
thank you
intimid8 is offline
Old 12-08-2022 | 09:59 AM
I used a home made pre luber I built from a hand pump, and pumped a couple quarts of oil into the return oil port towards the front of the engine. I could feel the pressure increase after the first quart.
87MirageIntruder is offline
Old 12-08-2022 | 10:06 AM
Thanks so much for that…
your motor seems to be opened?
mine is sealed and ready to start! Would This be accessible given mine is fully dressed. Excuse me, I am no mechanic…
intimid8 is offline
Old 12-08-2022 | 10:10 AM
Veteran: Army
That port is outside the oil pan mounting rail. Should have a threaded plug in it. Accessible even on fully assembled motor.
DrFeelgood is offline
Old 12-08-2022 | 10:29 AM
excellent. Thanks
do you know what fitting size is required
intimid8 is offline
Old 12-08-2022 | 10:38 AM
F-2 Speedy's Avatar
I think there 1/4 npt
F-2 Speedy is offline
Old 12-09-2022 | 10:17 AM
That picture I posted is on a 496HO engine, and that one uses a 1/2" NPT fitting. I'm not sure what the 700 has, I know some of the earlier gen blocks had smaller NPT fittings.
Just be sure to use the more forward of the 2 fittings, use the one that doesn't have a plug in it in my picture.
