702CI Gen VII
Seen this awhile ago then just recently in their Nov./Dec. print edition again.
Didn't read much into it until seen it in the print.
702CI
Anyone familiar with this builder?
Does this make anyone else scratch their heads?
It's clearly on a Gen VII block as he's using Raylar heads.
To get 702CI with a 5" stroke it would need a 4.727" bore in a 4.840" bore space block.
6.7" rods with 10.2" deck, so that's a 1" compression height piston.
Says he wanted to shed some weight from the reciprocating assembly over a blown 632.
Most of those are 4.75" stroke.
Obviously could of used aluminum rods and lighter pistons and whatnot over the 632.
No blower he gets rid of the load of driving it and the inertia of all the drive components.
But typically doesn't increasing stroke go the other way?
Increase reciprocating weight
Those heads enough?
Time bomb or not?
702CI
Those heads enough?
Time bomb or not?
There is some bad math in there on the CI or bore.
Huge lift, tiny exhaust valve, weird intake manifold.
That's my thought also. They didn't spec the bore in the article. On purpose? I dunno.
I think a lot of these builds and the corresponding write up are self submitted so that's that.
Funny about the .825 lift also because these are 2 quotes out of the article.
The mechanical roller camshaft features a 310/334 duration and .846/.800 lift with lobe separation of 114.
“The Raylars I set up myself for .825 lift with 14+2 LS 4/7 firing order swap,” he says.
Different than what used to seeing.
And in these days of HUGE HP, even the 1,000 estimate doesn't seem earthshaking with that many cubes.
But, just my .02 which after inflation now is only .004
5” stroke fits, I’ve heard the pistons start coming out bottom of the bore at 4.75. Maybe these blocks have longer bores than Big Ms?
why do you need a dyno? just take the base motor and the ad's say the headers are good for 150hp, the intake adds 50hp, etc. add it all up and you have a 700hp 327 sbc. dynos are just an added expense. throw in a 3/4 cam and you may make 750hp.
and yes I am kidding
but who knows till you hit the dyno with correct data equipment.Last edited by SB; 01-12-2023 at 04:56 PM.
