502 need help
Hey guys i opend up my faze chain on my 502 and this is what i got...
So when it lines up like this the valve is hitting the piston..
But when i put it like this then looks like everithing is ok...1 cil fiering 6 cil on overlap..On the first picture when i checked the cam the 6 cil was not on overlap but the 1 cil had closed valves...strange...Allso when i removed the chain gear from the cam i see that there are nubers writen on cam...it writes 32 cam with golden letters...What are your thinking about this?
Good morning profesor...
This is the best i have for now.I'm at my work place but as soon as i finish my job and get to garage ill take foto.
The crank gear had 3 keyholls it had letters A...letter R...and two 0 marks
Looks like its a Cloyes 3110 adjustable timing chain set
https://www.cloyes.com/hex-a-just-tr...110a-bb-chevy/
Im no expert but now when two 0 marks meet my 6 cil is fiering(closed both valves) and my 1 cil is in overlap
One thing that most people don't realize is that when you line up the dots on a timing chain, it is not cyl #1 at tdc, it is #6. That is why distributors get installed 180 deg off so often. Cylinder #1 tdc is when both dots are at the 12 o'clock position
