Stronger Prop Hubs?
I have Bravo -1 props This upcoming season I will be running 500hp engines. Just looking around randomly at different sites etc. and noticed on Teague's site that they mention something about 400hp hubs. This is something I never thought about. Is this something I should be looking into? They make different hp hubs? Also, and I think this is the most important question, how deep does the "up the hp rabbit hole" go? Is there a list somewhere of all of the things you will need to upgrade because of the hp increase? Thanks for your comments and help.
I'm guessing you're referring to the plastic replaceable hub. (STD HP)
They then offer the aluminum replaceable hub for higher HP. (400 HP+)
The other possible problem will become the Bravo 1 out drive. Some have claimed you can go 500-550 HP before things brake. (and careful throttle control) The first HP 500 (carb) came with a Bravo 1. After that, the HP engines started coming with the Bravo 1 XR.
Just as a semi-related observation and subsequent question...but my old Baja 208 Islander had the Yamaha Hyrda-Drive ( 454 Chevy coupled to Yamaha's unique hydraulic clutch outdrive) and it used SOLID hub props...there were no rubber inserts. I have seen from time to time similar 'solid hub' props for sale. What is the advantage/disadvantages? I know on the Hydra-Drive the hydraulic clutch protected the outdrive in the even the prop struck something.
Baja 252 Islander
Baja 252 Islander
Bajaman, That's interesting. Not that I am aware of everything boat related. Far from it but I never heard or seen that Yamaha drive system. I'm assuming you were not running a high hp mill in that 208? Was that drive pre Bravo-1? Was that considered at the time an "Upgrade" from an Alpha?
My observation of the solid hub stuff is probably what you are thinking. No way for a pressed in or drop in hub surviving really high hp and torque?
My 208 had the basic 330 hp 454. A couple of pics:
Baja 252 Islander
Baja 252 Islander
