E.O.I.C valve setings questtion >
Old 01-16-2023 | 11:00 AM
Default E.O.I.C valve setings questtion
Hey guys...simple question..I want to messure valve/piston distance and i'm doing the e.o.i.c valve settings.I have hidraulick roler lifters so the question is do they have to be fild with oil or not..thank you
Zole is offline
Old 01-16-2023 | 11:08 AM
Veteran: Army
When you are setting valve lash on hydraulic lifters you are compressing the compressible part of the lifter (that which would be pumped up with oil pressure when running).
Even if there was a way to "fill" them with oil you'd be pushing the oil right back out as you snug the adjuster nut down.
DrFeelgood is offline
Old 01-16-2023 | 11:13 AM
So it is ok to set the e.o.i.c when the lifter is dry and i can squize them with my fingers
Zole is offline
Old 01-16-2023 | 11:20 AM
Veteran: Army
When you set valve lash you are setting lifter preload. This is how much the lifter is compressed without oil (hydraulic pressure) being present. I can't really answer how easy it should be to compress a dry lifter, but when you are setting preload that process compresses a lifter just like when you squeeze it by hand.
Old 01-16-2023 | 11:43 AM
Than you doktor as allways...my respect to you.You are still on of my profesors
Zole is offline
Old 01-16-2023 | 11:55 AM
The distanc valve/piston is 0.043 inc...Is that ok
Zole is offline
Old 01-16-2023 | 12:05 PM
NO!
fbc25el is offline
Old 01-16-2023 | 12:12 PM
Originally Posted by fbc25el
NO!
To big?
Zole is offline
Old 01-16-2023 | 12:13 PM
Veteran: Army
To big?
Too small! You should be shooting for 0.100 inch or so.
Old 01-16-2023 | 12:20 PM
sorry...miscalculacion..0.433 inc
Zole is offline
